Steel Column Base Plate Modelling In Sap
Waqas Haider
Respected seniors,
It is my 1st post. I  have got help from this forum many times but posting 1st time.. i am a junior structural engineer..
i am to model a steel column resting at 8 ft concrete pedestal of isolated foundation...
The base of steel column is attached resting at pedestal with the help of a hinged type base plate...
but i am confused what type of constraint i shud provide at the connection of steel column base at pedestal....
i even dont know exactly what a constraint is...
i am to design foundations of column. so kindly let me know how to model it properly and accurately...
Thank you Waseem bhai for ur reply... i am infact confuse that i have two option to design isolated footing....
1st way is that i model steel column with hinged connection at base. the note down its reactions in SAP and do manual calculations for the design of footing and pedestal... the reactions, noted in SAP would be imagined at the top of pedestal of footing.. then i will have to transfer this reactions from top of pedestal at the top of footing along with the moments produced due to these reactions at the top of footing by multiplying these reactions with the height of pedestal. the i can use these Fx, Fy, Fz reactions along with moments Mx, My, produced due to this transfer because reactions are acting at top of pedestal and i have transfered this to top of footing... now i can design my footing for this Fx, Fy, Fz, Mx, My either manual or using safe........
2nd way i have is, I can model the very same pedestal at bottom of steel column and fix the base of pedestal... in this way i can get automatically, transferred moments (Which i was transferring myself by Fx*H or Fy*H) at the top of footing...
But the results of both of them are not matching. And I also cant understand what type of conenction i must provide at the connection of steel column to pedestal in SAP...... Which of my way is OK out of 1 and 2?
WAIT!
I dont understand why you are transferring your reactions from top of footing to bototm of footing? second thing is why you said the reactions on top of footing will produce moment at the bottom of footing?
Now I tell you what you do!
1-Apply pin supports to steel columns in SAP.
2-Note down the reactions for manual design or export to SAFE..(upto you).
3-If you do manual design then just design an isolated footing on this reaction.
Bearing pressure = reaction/area of footing
check shear
and design for reinforcement
simple!
Ni bhai... At bottom of steel column,, there is not footing... there is a concrete pedestal of 8 ft height.. and footing is below this pedestal.. so the reactions obtained from SAP, will not be at top of footing.. it will be at top of pedestal... and due to this reason, i want to transfer my reactions.............. i know how to transfer loads along with accompanying moments manually i.e. by multiplying each reaction with height of pedestal... but can i model this pedestal into sap along with steel column?? if yes, then how to model it properly?
If you are providing hinge support for column then release your moments for column by selecting the column member. However i would suggest you to make a fixed connection, in that case you don't need to release moment moreover it is easy to make on site, in Pakistan
A lot is going on this thread, and I would just point out 1 thing regarding "hinge type base plate".
Your base connections can be fixed or pin.
Depends where you place your bolts around column. If bolts are insider flanges, its pin, if outside, fixed or moment. You will have to design the baseplate accordingly.
Also the connection of column to baseplate matters and you can achieve a pinned connection by welding in a special way but to keep things simple, assuming fully welded column to baseplate, stick to bolt layout to determine if its pin or fixed.
Rest, you can transfer the loads like you said. Follow free body.
In addition to what Umar said about bolds inside or outside flanges...I would add that...
you can model 8 feet high concrete column just as you modelled the steel column. Add another line element made up of concrete (that is 8 feet high) directly connected to steel column. It will be a continuous (fixed) connection between 2 columns as mentioned in post#6.
Then at the base of concrete column you dont really need to model pedestal in SAP. just apply a suitable support according to post #7.
Hello Umar,
Can you please send me any reference book or document for your quoted statement?
"If bolts are insider flanges, its pin, if outside, fixed or moment. You will have to design the baseplate accordingly."
There is no need for any reference for that statement. Its simple. Flanges will resist moment and and when there are no bolts around flanges, there will be no couple (tension, compression) to resist the moment. Only axial load will be resisted by bolts near the web.
You don't need a reference book for this. Do a simple thought experiment. When bolts are inside the flange, there is no rotational constraint. However, when bolts are outside the flange, load path is throught base plate bending and considering a reasonably thick baseplate(which is 99% of the times) bolts would create a couple offering rotational restraint. You need to ensure that your bolts can handle interaction of shear and tension. This is standard parctise.
Hello.. so after analyzing in SAP, for baseplate design and connection, can I do it via SAP? or manually? or should I then  use the values in another software and what? All I need is how can I easily and perfectly design steel connections and baseplate using ETABS or SAP?
Edited by Juli
I do the connections manually, using custom made Excel worksheets. However, I use ETABS for main frame analysis & design.  You may develop steel connection design worksheets in MS Excel, a very powerful spreadsheet software, yet not very difficult for developing structural worksheets for routine design office work.
Steel column base plate connections are very important in transferring the column loads to the foundation. Often design engineers model and analyze the structure precisely using available software such as SAP2000, STAAD, ETABS, MIDAS, ... but in the design of base plate connections , they use simple methods that have not the correct calculation in comparison with the real behavior of base plates.
So, I want to introduce you, a professional software for the modeling, analysis, and design of steel column base connections that is different in comparison to the available softwares.
ColumnBase is integrated software for analysis and design of column-base connections using three-dimensional finite element modeling.
This software provides a three dimensional model of connection parts (including foundation, grout, column, base plate, stiffeners, etc.) for finite element analysis, and by applying contact modeling analysis to connection parts in simultaneous loading cases, analyzes connection model and finally applies its results according to designing handbooks and standards. Outputs of this software have been proved by the most reliable laboratory experiments, and its accuracy is incomparable.
Visual and user-friendly interface, easy to use and precise results.
Analysis results verified by several valid experimental tests and realistic simulation of base plate behavior is performed by using it.
Analysis results are used for the automatic design of connection components according to standards/codes.
It is now available for free download at http://pceesoft.com/download
View its introduction on LinkedIn http://www.linkedin.com/pulse/introduction-columnbase-software-amir-hasanpour
Introduction to Product: http://pceesoft.com/product
Linkedin Article: http://www.linkedin.com/pulse/introduction-columnbase-software-amir-hasanpour
View Sample Report at SlideShare:
https://www.slideshare.net/ircivil/columnbase-plate-foundation-design-report-how-to-design-base-plate-connections-sample-design-report-columnbase-software-pceesoft-inc
Edited by Amir_hp
Modify
    • I am designing a G+2 factory building founded on dense sandy soil as per our geotechnical investigation report.   Load considered:  (As Client was not sure about the purpose of use)  Live Load on Slab= 3.0 kN /m2 Dead Load on Slab= 1.5 kN/m2   (other then Self weight) Grid Spacing: 27'9"x21'3"  Plot Dimensions: 56'x165' Characteristic Load on Columns: (decisive case) Dead Load: 1900 kN Live Load: 950 kN The report recommended bearing capacits: Isolated Footing: 160 kPa at 2.0m depth  Settelment within 25 mm Raft foundation  300 kPa  at 2.0 m below existing ground level (EGL), With the column loads of around 2800 kN and grid spacing isolated footings would require very large foundation sizes leaving little or no clearance between footings and cause overlap issues. Therefore i decided to go for raft foundation.   However, the site condition is such that: The EGL (existing ground level) in the report corresponds to be the site’s current level +0.0 m, while the outer road level is about +0.9 m higher. Our finished factory floor will be at +1.5 m. Now i am evaluating two options: Option A – Construct the raft foundation at the recommended -2.0 m below EGL (per the GI report), then build up columns, cast a plinth beam at the raised level, backfill up to the required ground/floor level, and finally prepare a floor over the compacted backfill. Option B – Raise the site to match the road level using engineered, well-compacted backfill, and then construct the raft foundation directly at the new raised ground level, allowing the raft slab itself to serve as the factory floor. I want to understand: Which option is more technically sound and economical considering bearing capacity, settlement control, and long-term performance? Is placing the raft on engineered backfill (Option B) acceptable practice if compaction and quality control are ensured, or is it safer to strictly follow the geotechnical recommendation (Option A)? Any insights or experience-based advice on this choice would be highly appreciated. Furthermore:  Are the load assumed too conservative? Kind Regards Abdul Malik
