Cross Bracing + Moment Resisting frame
Osama Anwar
Yes, you can. In that case, it will be either a Dual System if the produced lateral load resisting system is enlisted in your lateral load resisting systems table, or it may be a "Combination of two different framing systems" in the same direction. For the 1st case, your table will say whether it is permitted in your seismic zone or SDC and up to which height it is permitted, and for the other type both the framing systems shall be permitted separately in the table. For the latter case, you have to use the lowest R value and the corresponding Cd and Omega value for that lowest R.
If your case is not seismic, only wind and if you want to use cross bracing to lower your structure sway, in that case there seems to be no problem.
Which code r u using?
On 2/19/2024 at 7:23 AM, Osama Anwar said:
Can we provide cross bracing in a moment resisting frame? Why can't I find any example?
In this case, for lateral load resisting system, the system will work as braced frame since braced frame stiffness >> moment frame.
The reason why you can’t find an example is that moment frame when provided with braced frame is just adding extra cost - it’s not needed and totally redundant.
