Required Qualification Of Soil Investigator
EngrUzair
Aoa.
What do you think, should be the qualification of a person, authorized to carry out soil investigation, and to provide allowable soil bearing pressures for the design of foundations? Whether he/she should be a civil / geotechnical engineer, or a normal geologist having no engineering degree?  Reference to relevant rule or code, if any?
  • 6 months later...
Uzair,
Where I work, it is mandatory that all geotechnical reports to be reviewed and stamped by Professional Geotechnical Engineers before they can be issued for use. Normally, geotech engineer would also visit the site, take the samples and an EIT would assist him make a report. But he is responsible for all engineering content in it.
uzair
i think that just qualification is not the criteria for geotech investigations experience is also improves judgement. we have geotech reports which are total mess and stamped by geotech engineers. on site there is  fill and report tells refusal and vice versa. samples are collected by non technical personal and report is generated by copy paste method professionally. no calculations are provided for the bearing capacity or other parameters recommended in report just equations are written. and "sonay peh sohaga" there is no review of geotech report required or performed, what reports says you have to follow blindly. structural designs are vetted/reviewed but geotech report is not, i don't understand this.
there are grey areas in RC design but there are total black areas in geotech. and these black areas lead to complex problems after construction and make structural designs to be blamed while good geotech report provide basis for the safe, economical design of structures.
samples should be taken by trained technical staff and lab works must be monitored by geotech professioanl either a geologist or geotechnical engineer. better is geotechnical engineer. in pakistan contractors are performing investigations without any supervision and generating reports stamped by ill-professionals by minute sum of money. legal requirement is the report stamped and signed by a geotech consultant or geotech PE
    • I am designing a G+2 factory building founded on dense sandy soil as per our geotechnical investigation report.   Load considered:  (As Client was not sure about the purpose of use)  Live Load on Slab= 3.0 kN /m2 Dead Load on Slab= 1.5 kN/m2   (other then Self weight) Grid Spacing: 27'9"x21'3"  Plot Dimensions: 56'x165' Characteristic Load on Columns: (decisive case) Dead Load: 1900 kN Live Load: 950 kN The report recommended bearing capacits: Isolated Footing: 160 kPa at 2.0m depth  Settelment within 25 mm Raft foundation  300 kPa  at 2.0 m below existing ground level (EGL), With the column loads of around 2800 kN and grid spacing isolated footings would require very large foundation sizes leaving little or no clearance between footings and cause overlap issues. Therefore i decided to go for raft foundation.   However, the site condition is such that: The EGL (existing ground level) in the report corresponds to be the site’s current level +0.0 m, while the outer road level is about +0.9 m higher. Our finished factory floor will be at +1.5 m. Now i am evaluating two options: Option A – Construct the raft foundation at the recommended -2.0 m below EGL (per the GI report), then build up columns, cast a plinth beam at the raised level, backfill up to the required ground/floor level, and finally prepare a floor over the compacted backfill. Option B – Raise the site to match the road level using engineered, well-compacted backfill, and then construct the raft foundation directly at the new raised ground level, allowing the raft slab itself to serve as the factory floor. I want to understand: Which option is more technically sound and economical considering bearing capacity, settlement control, and long-term performance? Is placing the raft on engineered backfill (Option B) acceptable practice if compaction and quality control are ensured, or is it safer to strictly follow the geotechnical recommendation (Option A)? Any insights or experience-based advice on this choice would be highly appreciated. Furthermore:  Are the load assumed too conservative? Kind Regards Abdul Malik
