Pile Cage Lifting
m_naeem_b
Dear all,
Any one design hooks and stiffeners for pile cage for lifting from crane?
and necessary welding calculation and specification according to Code and standard regarding this.
or any one have any documents or data regarding this issue?
I have to provide calculation with drawing:
1. welds definition (calculation),
2. The hooks that will hang the rebar cage on the casing during concreting. I have to provide dimensions and weld definition.
3.  Definition of stiffeners inside the casing. : position of stiffeners and dimensions and  weld definition.
4.  Definition of lifting points
Aoa.
I have not designed lifting hooks. However, in principle, design of hooks and lifting arrangement should be done in a way, similar to the design of a steel frame. (Deciding a suitable layout for the lifting device and hook., calculating total load to be lifted, determining members, welds, and stiffener sizes , depending upon load distribution to various members and joints...)
Design of these lifting devices and hooks, is generally to ensure safety of work people during construction. In USA, generally, OSHA regulations provide basis for the safe design of these devices.
A good search on the internet might help you collect specific details relevant to your requirement.
The lifting lugs are available from 3rd party and their max capacities are listed. You just need to see that your lifting reaction at that point is less than lifting lug capacity. What you need to do is to weld a steel plate to reinforcement cage and lifting lug could be attached to the plate. This is a improvised solution. I have never done a rebar cage lifting but I do have done steel module lifting calculations. Weld specifications would depend upon your base metal strength. I am out of office. Can post somethinh when I return to Canada from Pak.
Aoa.
Naeem!
I have done a little search on google regarding design examples for lifting hooks and devices, and found following links on the first page of search results. There will be a lot more on later search pages as well.  (mostly the designs data is based on ASME BTH (Below The Hook) 1 code)  :
1. spreader bar and lug caculations: http://www.pveng.com/ASME/ASME_Samples/ASME_SpreaderBar/ASME_SpreaderBar_Calcs.pdf
2. Lifting lug design:  http://www.webcivil.com/stlug.aspx
3. Spreader bar design process: http://www.spartaengineering.com/spreader-bar-design-process/
4. Below the hook equipment. Has several pdf files about lifting devices.: http://www.avonengineering.com/below-hook-lifting.php
etc. etc.
Try searching yourself. You may surely get much more relevant data than I have listed above.
Thanks Mr Uzair;
above links are very informative. It will InshAllah definitely help me.
Secondly, how to do calculation for welding of bars when cage of pile is lifting? and how to define lifting points on cage?
Thanks you very much.
