Hi guys just to discuss with you my understanding of crack widths in Environmental structures according to ACI.
Normal structures
1. ACI 318-95 based on statistical method of Gergely & Lutz 1968 limits Z based on exposure. We are calculating crack widths here. (Normal structures)
2. ACI 318-99 proposed limiting the spacing and removed actually calculating the width and also removed the exposure conditions. For example for beams and one-way slabs s (in) = 540/fs -2.5cc or in other words limiting the fs=0.6fy  (For normal structures)
3. ACI 224R-01 references method 1 and 2 above and 3 european codes.
The most confusing part is the table in which Nawy suggests 0.1mm crack width for water-tight structures. The whole document is for normal structures except this line. And people are following this line and refer to this document for water tight structures. I mean its just a suggestion and by the way this method 1 is obsolete now since ACI 318-99 (see point 2 above).
Water tight structures
1. ACI 318-08 states clearly that for watertight structures ACI 350-06 codes should be used.
2. ACI 224.4R-13 also specifically states that for watertight structures walls in section 7.4, we should use ACI 350-06.
3. ACI 350-06 for water tight structures does not recommend calculating a number for crack width but rather limiting max steel stress in bars to be 20k ksi or fs=0.33fy for normal conditions.
To sum it up,
Philosophy of crack width control is not to calculate probable crack widths but to limit the max stress in steel bars.
For normal structures: fs=0.6fy and for water tight structures fs=0.33fy
  • 4 years later...
Normal structures
To sum it up,
@Rana, I am working on a structure where I have to use this. I have provided my conclusions here:
I couldn't find the reference that you have discussed about limiting stress in reinforcement to 0.33*fy based on ACI 350-06. May be I am missing something. Have a look and let me know when you get some time.
I was referring to ACI 350-06 Appendix I (Working stress method) which limits fs to 20ksi or 0.33fy if fy=60ksi.
Quote
"RI.3.2 — Permissible stresses in reinforcement are established to provide enhanced crack control. Values given for flexural and shear reinforcement are suitable for reinforcing bars spaced at no more than 12 in. centers. Direct tension forces can produce concrete tensile stresses over an entire cross-sectional area of concrete, resulting in full-depth cracking and exposure of all reinforcement at a section location. Therefore, low permissible stresses are used for direct tension members to limit resulting crack widths. Some designers prefer to use a permissible stress of 14,000 psi for grade 40 reinforcement in hoop tension members, based on their good experiences with designs using the earlier version of the PCA publication, “Circular Concrete Tanks Without Prestressing.” ACI 224.2R provides guidance for estimating crack widths in axial tension members."
