Rectangular Column Footing Design
myasirkaram@gmail.com
isolated footing for Rectangular Column of 18x12 is supposed to be designed. Now i must choose Rectangular footing or i may also carry with Square isolated footing design. if i can carry with square footing what dimension should i choose for the punching shear/one way shear/ ultimate factored moment? either 18 or 12?. and if i must choose rectangular footing guide me through its design steps thoroughly.
You may use either a square or a rectangular footing, for your column. Choice usually depends upon column grid spacing along the two perpendicular axes & the shape of floor area supported by the column.
Following link provides detailed procedure of designing a rectangular footing, supporting a rectangular column,  in accordance with ACI 318.
http://www.ce-ref.com/Foundation/Spread_footing/Rect_FTG/FTG_Rect.html
