Rebar Concrete
done_87
Hi, I am currently renovating my house. I am trying to understand the rebar concrete drawing. Attach here is the snapshot of the drawing.What does 68XR8-125 stand for? I believe R8 is 8mm stirrups with 125mm distance apart. Also what are the significant of the distance 850 and 900. What it actually indicating. I am a chemical engineer would like to improve my knowledge in structural engineering. Thanks.
Thanks Rana for your reply. I understood on the stirrups however on the rebar from what I saw at the site there are four bar arranged in rectangular shape (125 X450). That why I still cant see the connection why that distance has any significance. Do you mind elaborating further.
The distance has significance as it shows the length in which more reinforcement is required than the rest of the beam.
Concrete is poor in compression. Reinforcement or rebars are used to provide required tensile capacity that concrete can't provide by itself. The reinforcement requirement varies along the length of the beam. For a simply supported beam (beam with 2 supports) more reinforcement is required at the middle than at the ends (like your case). Therefore, instead of providing continuous bars throughout, engineers provide additional bars where extra reinforcement is required. In that was they save on steel quantity The only catch is that the additional reinforcement should be long enough so that it develops completely. You can read more about development length of rebars here.
    • I am designing a G+2 factory building founded on dense sandy soil as per our geotechnical investigation report.   Load considered:  (As Client was not sure about the purpose of use)  Live Load on Slab= 3.0 kN /m2 Dead Load on Slab= 1.5 kN/m2   (other then Self weight) Grid Spacing: 27'9"x21'3"  Plot Dimensions: 56'x165' Characteristic Load on Columns: (decisive case) Dead Load: 1900 kN Live Load: 950 kN The report recommended bearing capacits: Isolated Footing: 160 kPa at 2.0m depth  Settelment within 25 mm Raft foundation  300 kPa  at 2.0 m below existing ground level (EGL), With the column loads of around 2800 kN and grid spacing isolated footings would require very large foundation sizes leaving little or no clearance between footings and cause overlap issues. Therefore i decided to go for raft foundation.   However, the site condition is such that: The EGL (existing ground level) in the report corresponds to be the site’s current level +0.0 m, while the outer road level is about +0.9 m higher. Our finished factory floor will be at +1.5 m. Now i am evaluating two options: Option A – Construct the raft foundation at the recommended -2.0 m below EGL (per the GI report), then build up columns, cast a plinth beam at the raised level, backfill up to the required ground/floor level, and finally prepare a floor over the compacted backfill. Option B – Raise the site to match the road level using engineered, well-compacted backfill, and then construct the raft foundation directly at the new raised ground level, allowing the raft slab itself to serve as the factory floor. I want to understand: Which option is more technically sound and economical considering bearing capacity, settlement control, and long-term performance? Is placing the raft on engineered backfill (Option B) acceptable practice if compaction and quality control are ensured, or is it safer to strictly follow the geotechnical recommendation (Option A)? Any insights or experience-based advice on this choice would be highly appreciated. Furthermore:  Are the load assumed too conservative? Kind Regards Abdul Malik
