Axial compressive capacity for concrete
Miller
How are you?
When I designed RC frame using ETABS some columns will fail because of the message "axial comressive capacity for concrete exceeded limit"
How can I manage this on my modeling?
You will need to try a column having a larger cross-sectional dimensions.
It should not be hard to manually calculate the required column size, using the required axial compression capacity,  according to the applicable material design code.
