Torsion Value for beams in ETABS
Engr. Muhammad Salman
Dear Friends!
I have recently modeled six stories building in ETABS for Zone 3 and soil type SD. After design, I saw that several beams failed in Shear force and torsion "Shear stress due to shear force and torsion together exceeds the maximum allowed" But when I reduced the torsion value up to 0.1, all beams passed. Is it suitable for Special moment resisting beam? or I should increase the beam dimensions? Please help
Dear Engr. Salman,
As you have said yours is a SMRF system, it would be better if you try to avoid reducing the torsion modifier to 0.1, however in some cases even if you increase the beam depths to 1000 mm it still fails or increase the width to say 400 mm or 500 mm. So try to increase your beam cross section but if it is still failing then reduce the modifiers. The practice of reducing the modifiers is not wrong as you are in a way transferring the torsion from beam to other structural members.
Thanks and Regards,
Areeb Ahmed.
