Reinforcement Overrides for Ductile Beams
Maleeha Joohi
SAP2000 has this option for beam reinforcement & I am not able to understand it. Lets say if i have specified reinforcement ratio which i have got from conventional formula e=As/bd & shear reinforcement. How provide that specific ratio using these command as shown in attached picture.
PS can anyone tell me how to provide stirrups in section designer option.
Maleeha,
Here is a description of the option:
Quote
  • Reinforcement Overrides for Ductile Beams options. The reinforcement overrides are specified areas of longitudinal reinforcing steel that occur at the Top and Bottom of the left and right ends of the beam. These overrides are used by SAP2000 as follows:
      • In the Concrete Frame Design postprocessor
        • When the design shear in a concrete beam is to be based on provided longitudinal reinforcement (that is, the shear design is based on the moment capacity of the beam), SAP2000 compares the calculated required reinforcement with that specified in the reinforcement overrides and uses the larger value to determine the moment capacity on which the shear design is based.
        • When the minimum reinforcing in the middle of a beam is to be based on some percentage of the reinforcing at the ends of the beam, SAP2000 compares the calculated required reinforcement at the ends of the beam with that specified in the reinforcement overrides and uses the larger value to determine the minimum reinforcing in the middle of the beam.
        • When the shear design of columns is to be based on the maximum moment that the beams can deliver to the columns, SAP2000 compares the calculated required reinforcement with that specified in the reinforcement overrides and uses the larger value to determine the moment capacity of the beam.
      • For any degree of freedom in the frame nonlinear hinge properties assigned to a concrete member that is specified as default, SAP2000 calculates the hinge force-deformation properties based on the larger of the calculated required reinforcement at the ends of the beam (assuming that run the design has been run through the Concrete Frame Design postprocessor) and the specified reinforcement overrides.
Source: http://docs.csiamerica.com/help-files/sap/Menus/Define/Section_Properties/Frame_Sections/Reinforcement_Data_Form.htm
Thank you but i have already gone through this. I just wanted to know if I have certain reinforcement ratio & spacing then how i can give that as an input . can this be done by using overrides for ductile beam commands or there is any other way. actually its not clear to me that in what terms you fill thses over rides for ductile beam command. what units..etc
Quote
Access the Reinforcement Data form as follows:
  1. Click the Define menu > Section Properties > Frame Sections command to display the Frame Section Properties  form. Then do one of the following:
      • Click the Add New Property button to display the Frame Property Shape Type form, select the Tee, Angle, Rectangular, or Circle shape and a concrete Material type; click the OK button (or double click the Section shape) to display the Frame Section Property Data form.
      • Highlight a previously defined Tee, Angle, Rectangular, or Circle section definition and click the Add Copy of Property or the Modify/Show button to display the Frame Section Property Data form.
  1. Click the Modify/Show Rebar button.
Source: http://docs.csiamerica.com/help-files/etabs/Menus/Define/Section_Properties/Frame_Sections/Frame_Section_Property_Reinforcement_Data_Form.htm
The above might work for you. I don't have SAP2000 installed so I can't really check what I find on internet but I do remember that you could either design a new beam or check existing one very easily. If the above doesn't work, try this link:
https://www.researchgate.net/post/How_to_provide_beam_reinforcement_in_sap2000_with_R_F_to_be_check_option_just_like_option_provided_for_column_in_sap2000
Things have changed so much since I was working on SAP200.
Edited by Ayesha
  • 10 months later...
    • I am designing a G+2 factory building founded on dense sandy soil as per our geotechnical investigation report.   Load considered:  (As Client was not sure about the purpose of use)  Live Load on Slab= 3.0 kN /m2 Dead Load on Slab= 1.5 kN/m2   (other then Self weight) Grid Spacing: 27'9"x21'3"  Plot Dimensions: 56'x165' Characteristic Load on Columns: (decisive case) Dead Load: 1900 kN Live Load: 950 kN The report recommended bearing capacits: Isolated Footing: 160 kPa at 2.0m depth  Settelment within 25 mm Raft foundation  300 kPa  at 2.0 m below existing ground level (EGL), With the column loads of around 2800 kN and grid spacing isolated footings would require very large foundation sizes leaving little or no clearance between footings and cause overlap issues. Therefore i decided to go for raft foundation.   However, the site condition is such that: The EGL (existing ground level) in the report corresponds to be the site’s current level +0.0 m, while the outer road level is about +0.9 m higher. Our finished factory floor will be at +1.5 m. Now i am evaluating two options: Option A – Construct the raft foundation at the recommended -2.0 m below EGL (per the GI report), then build up columns, cast a plinth beam at the raised level, backfill up to the required ground/floor level, and finally prepare a floor over the compacted backfill. Option B – Raise the site to match the road level using engineered, well-compacted backfill, and then construct the raft foundation directly at the new raised ground level, allowing the raft slab itself to serve as the factory floor. I want to understand: Which option is more technically sound and economical considering bearing capacity, settlement control, and long-term performance? Is placing the raft on engineered backfill (Option B) acceptable practice if compaction and quality control are ensured, or is it safer to strictly follow the geotechnical recommendation (Option A)? Any insights or experience-based advice on this choice would be highly appreciated. Furthermore:  Are the load assumed too conservative? Kind Regards Abdul Malik
