Modal Analysis
Hamza Ahmad
Aoa everyone.
Another question on modal analysis lol.
I have saw a lot of posts in the forum regarding modal analysis but still have questions in my mind. Sorry if questions seems to be silly.
 if a mode (deformed shape) in which mass is participation 90% it means that following mode is attracting more EQ force and how can we use the following mode time period in etabs as we have already define time period in static load cases (Program Calculated)   ??
Secondly for response spectrum analysis it is necessary to perform modal analysis in etabs and when Etabs calculate base shear from both static procedure and RSA which one base shear is used in final design calculation by etabs ?
If time period calculate by etabs is less then Ta then we have to use Ta, so how can we change the time period in etabs to Ta ??
You need to check first if the code requires you to perform a modal response spectrum analysis or equivalent static analysis. If, your structure falls for modal response spectrum analysis, you do it and it helps you see which modes are attracting more mass and subsequently more force. That time period is independent of your equivalent lateral analysis as both are different methods. So, there is no point in taking information from modal analysis to use it in equivalent lateral analysis.
Yes, modal analysis is necessary. Between equivalent static and response spectrum, use one method based on criteria provided by Code.You might have to run a static analysis first to note the base shear and then run a response spectrum if code requires.
ETABS has checks built in to make sure it uses the corrects time period. You can print the summary sheet to see that ETABS makes sure the limits sets by code are followed.
