Frame Release clarification
Hasan009
Hello,
I am new grad and want to understand better about frame releases.
Can you please confirm if the partial releases are correct:
1. Beam as rigid to the wall – no release in rigid connections
2. pinned connection of beam to the column - release moment in major and minor (M2, M3).
What could be examples where we intend/not intend to frame release.
  • 7 months later...
if you want to model a beam as simply supported beam , then you will need to end realese , so the beding moment draw as for simply supported beam, other wise without relase , depending upon the stiffness , negative and positive both moments comes in beam
