Beam Column Joint and Strong Column Weak Beam Check
Rifat
On 7/14/2019 at 7:08 PM, Rifat said:
Dear,
How to check beam-column joint & strong column-weak beam in Etabs?
Thanks in advanced
Rifat
As per ACI code, for strong column and weak beam the nominal flexural capacity of the column must be greater than atleast 1.2 times of the beam flexural capacity.
In Etabs the option displayed in the snap will do your job.
That means if the value is more than 1.2 then it will pass for strong column-weak beam capacity?Roger that.
How vto check beam-column joint check in Etabs?
Yes u got that right. Or u can say that the ratio of the nominal capacity of the column to that of the beam should be greater or equal to 1.2 for strong and weak beam check.
What do u want to check in beam-column joint? Shear particularly?
Edited by abbaskhan2294
  • 5 months later...
