Minimum Area Of Steel In Etabs
SMAQ
Hello Fellow Engineers.
Well I do Know that, Etabs Checks all the members for there minimum area of Reinforcement as per code. But I came across one design of mine where I see for a beam size of 228.6 mm wide and 304.8 mm deep. Etabs gives Bottom reinforcement less than what I calculated manually. I am attaching a few pics for the problem. I request to please put some light on this. The beam is designed for M20 and Fe 415 steel.
Check following:
  • Design code assigned in the software
  • RCC design manual of the software and find how it calculates this for the design code of your interest
  • If you still reach at the same conclusion, ignore these results. The software can do that because of some bug.
Etabs only gives you minimum area of reinforcement incase of slabs and columns provided that the designed reinforcement is less than the minimum area of reinforcement as per design code. However as far as design of beams are concerned, you must always calculate the area of steel manually and check it with the designed reinforcement by etabs. Etabs always give the designed reinforcement for beams whether its less or more than the minimum area of steel.
Edited by abbaskhan2294
ETABS does give correct values of reo (it does take into account the lower/upper limits of reo for a particular code).
On 9/22/2019 at 7:25 PM, BAZ said:
Check following:
Totally agree and recommend first 2 points. However, I do not think, ETABS in 2019 has bugs for such simple things. Yes, it does have few bugs like any other package but for sure not related to these basic things.
Please check what code says when you provide As = 1.33 x Asreq ???
And why ETABS giving less moment and reinforcement than what you getting manually is totally a different question and depends if you are modelling it right or if you are manually calculating it right.
@Rana How to calculate reinforcement for pattern live loads in ETABS for a whole structure automatically?
