SECTION DESIGNER ETABS/SAP2000
Iftikhar Hussain
ASSALAM O ALAIKUM.
HERE IN ATTACHED FILE, THERE are  MOMENT CURVATURE  AND MOMENT INTERACTION DIAGRAM FOR
steel rc section,
frp rc section and
steel+frp rc section.
FROM THESE OUTPUT SECTION DESIGNER RESULTS WE CAN SAY IT IS ACCEPTABLE(IN GENERAL)... but values for the moment in MOMENT INTERACTION for the same section reinforced with steel and FRP are also same, while there is a very little change with steel+frp reinforced section...
would it be ok to just consider the results of MOMENT CURVATURE DIAGRAM WhILE IGNORING MOMENT INTERACTION diagram results.?
AND ALSO
how can we consider these results in defining (user) plastic hinges for beam and column?
Section designer ETABS 1.pdf
First for beam it will be MM hinge i.e. moment hinge. You have to define max moment and rotation or curvature corresponding to that moment.
For column it will be P-M-M hinge. Here you have to define the balance axial load, balance moment, ultimate axial load and moment. Along with curvature of column at each corresponding moment.
