Etabs/sap2000 Dome Geometry
UmarMakhzumi
Posting this thread to break the ice. Modelling domes is very easy in Etabs/SAP. All you need to do is to draw the curvature of the dome in elevation by a series of straight lines, but draw only the one half. Then using the apex at centre point, radially extrude the line say 24 times at 15 degree intervals (or 48 times at 7.5 deg intervals. This feature is under Edit> Extrude Lines to areas. You can further use this geometry for Finite Element Analaysis.
  On 5/26/2012 at 6:47 AM, Muhammad Adnan Alam said:
sir i am learning ETAB. now a days.i want to ask you that is it possible to design and analyse a masonry wall on ETAB or on SAP. if yes then can you give me some guidlines about this.
Adnan, i am afraid ETABS is not a very good solution for masonry walls design. Etabs is designed as a frame analysis program. I have used a software called MASS(http://www.masonryan...ralsystems.com/) It design masonry as per Canadian Building Code. Your best bet would be to get a masonry design handbook and see examples to get a feel of how to design it, or if you want to try doing it on a software, look for educational version one. Can you update a bit about what do u plan to do? may be I can help you develop a spreadsheet to design what you want to..
sir basically i am doing final year project on earthquake resistant masonry structures and our proposal is to reinforce hollow concrete block masonry wall and also the reinforcement of infill walls in frame structures . and i need a software by which i can check where in the wall stresses are high and upon that we will give the no. , spacing and length of reinforcement bars in the wall, and one more thing , you have mentioned that you are using MASS software so can you send me file of this software on my e mail address. i will be very thank full to you
Sir, Umar there is one software for masonry which i am using to get the capacity of the structure i think if adnan need the streeses or forces on the wall then he can try using 3Muri software its also a free ware you can download and analyse your structure for the seismic response it works on Euro code but you can define own limitations as well. But only analysis are much better with this one...
sir you talk of 3muri software.i have downloaded it.and now i need some help to start with, can you please help me in this regard. i have a demo version of it (only available). i will be thank full to you. i have to do my under grade final year project
adnan first you have to make your autocad drawing according to 3Muri format its easy just you have to draw the center line for the main load bearing walls as when you sketch the wall in the software it works with the center line. so make your drawings in this format and then you can just import your plan in the software i am sending you on your email id an example drawing and also a PDF file for how to use the software in this you will understand very easily what is the procedure of using this software i hope this works or else you can ask.....
and please keep in mind as you are using the demo version so your file must not be big enough i mean to say that the plan which you want to analyse must not be big as there will be lots of nodes in the model and demo version is limited to several nodes only so remember .....
Asad i think you have to look that is there any room or terrace what kind of structure on the slab .... But keep in mind that you have to use inverted beams for that as this will reduce loading to some extend compared to the one in which you design normal hanging beam....
thank you sir....i have one more question regarding ETABS.in our design office we mainly use ETABS and we always change the modifiers of beams columns and slabs and no body can explain the reason of doing it kindly tell me if u know about it...we usually change the modifiers as follows.
BEAMS
a)moment of inertia about 2 axis=0.35
b)moment of inertia about 3 axis=0.35
c)torosional constan=0.00001
COLOUMNS
a)moment of inertia about 2 axis=0.7
b)moment of inertia about 3 axis=0.7
c)torosional constan=0.7
  On 6/9/2012 at 5:17 AM, asadishaq said:
give me any suggestion about how to design a economical 45ft cantilever slab.. beams can be provided at edges only.
I dont know what is the plan, but for that length of cantilever girders should be pre-stressed . Make your you do all kinds of serviceability checks too in addition to strength checks and also design it for a higher base shear, as said in UBC.
P.S torsion can be there too. watch out!
BEAMS
COLOUMNS
Stiffness modifiers, Read ACI chap 10 commentary.
The question asked by asadishaq has been moved to a new thread. http://www.sepakistan.com/topic/63-safe-iterative-uplift-analysis/
Its always a good idea for making a new thread and ask questions there. allows other members to look at it and search.
Thanks Rana Waseem for reporting that.
  • 3 years later...
  • 2 years later...
  On 5/25/2012 at 8:56 PM, Muhammad Hassan said:
I remember whn i modelled 40 ft dia doom of B-17 Mosque on ETABS using this practice. Sir umer thanks for sharing this
Dear Muhammad Hassan,
can you share your model as i am designing a dome with radius 40'. Now i have designed it manually but since the dimension is very long, i have difficulty in designing the circular beam under dome. i had searched the forum but every attachment has been either removed or is no longer available. now i am trying to model and design it in etab but what properties should be assigned. and should i be designing it as beam properties?
