Rules of Thumb for Providing Reinforcement in Joints
hali
AOA everyone,
I have always kind of struggled to understand how exactly you provide reinforcement in joints like beam-column joints or joints of box culvert. More specifically, how to ensure transfer of moment through the joint. Does anyone have any pointers or rules of thumb for providing reinforcement in joints?
Thanks!
Culverts - first determine bending moment (tensile surfaces) and reinforce either one of two ways:
See hand sketch below - once you know moment and effective depth of tension reinforcement you can design the joint.
1. U-bars coming in from slab and wall and connecting in corner.
2. or, Top/outer bar bent around the joint.
3. Option 3 is to use L-bars at joint,
- see sketch below for all three ways you can detail a culvert corner - your engineering judgement is determine which detail best suits your design!
Spacing of reinforcement tend to be closer to limit serviceability stress and hence crack width in concrete to <2mm - for reinforcement durability, and to stop water corroding the reinforcement, and to have a watertight structure; Movement joints are tricky in culverts. Make sure the concrete (or cement) selected is ok for, (i) against corrosive soils and (ii) chemicals in (waste) water.
Thank you @Simple Structures for taking the time out to draw all that. That was very helpful.
For the most part, I can figure out where where the rebars are to be provided (tension locations), its the fine detailing of the rebars that I want to get comfortable and confident at.
