Modelling staircases in softwares for structural analysis
SAL9000
Greetings everyone!
I am fairly new to the industry and have little knowledge about the usual practice in designing structures. I am confused about how staircases should considered in structural engineering softwares. Should they be modelled as inclined shells, as a flat horizontal membrane, or by just simply leaving it as an opening (apply loads on adjacent beams)? Is it a case to case basis, and if so, when should we model staircases for each type and why?
I am looking forward to your recommendations, thank you.
SAL9000,
There are different opinions on it.
One opinion is that Stair cases should be modelled as they can alter the response of your structure. Seismic Design of Reinforced Concrete and Masonry Buildings sheds some light on it. You can model them by inclined shells. If you model staircases, then you have to detail them for the force they attract. Very important.
Other opinion is that they shouldn't be modelled as they are not detailed to take the seismic force. The normal practice in Pakistan is not to model them.
If you ask my personal opinion, I would suggest modelling them.
Thank you.
  1. Interesting question:
1. Yes you can model them as inclined shell, and detail the stair and slab connection accordingly.  Half landings make the modelling and force transfer a bit tricky.
2. In many high rise buildings, the staircase is enclosed in a vertical concrete shaft (walls)- for fire protection reasons. Here the concrete shaft (housing the stairs and lift cores) tends to performs building stability function also.
3. Nowadays the core walls are cast by "slip-forming" hence many stairs are precast, lowered down into the shaft by crane and fixed to the shaft walls. In the past as the core walls were 'jumped' level by level, the staircases were cast in-situ with slab/walls. Speed of construction and project programme become a consideration too.
4. Apart from a structural engineering role, stairs also perform a safe protected fire escape route function, a legal requirement in many countries' building regulations, hence concrete or block wall enclosures are provided around stairs.
5. Therefore, if the staircases are cast in-situ (not precast) then detail and model them accordingly.
With reference to this statement, I have a question regarding detailing of lift wells. If we design lift well existing in a building system for the gravity load only by ignoring its shear and flexural stiffness against lateral loading in the model and detail it with nominal reinforcement for gravity load only and putting all the lateral load on columns. Then how the wall will behave in case of seismic ground motions? Will it crack loosing the serviceability?
In the computer model, if a designer has assumed that the stairs do not provide any lateral stiffness, then it is the responsibility of the designer to detail the connection such that it reflects the behavior of assumed connection in the model.
Thank you for this. Yes, the comment goes both ways!
