Masonry structures
Minha Abbasi
On 1/23/2021 at 12:57 AM, Abdullah Alvi said:
You have to define M1500 from material properties then divide its  E by 2, modify its material property and take its compressive strength 750lb/in2. that's it.
What is the basis for this?
Why E is not divided by 2.5 or 3?
Masonry has no to limited, out of plate strength. How are you making sure, your modelling approach is different from modelling a shear wall..?
According to my knowledge, the masonary available in pakistan is of satisfactory strength, that's why we take its strength and E half of original. Also i don't have much experience in shear wall modelling in Etabs. The Answer given by me was according to my knowledge and its not final, as i am a fresh structural engineer and want to learn from this platform. Thanks.
My question is, why we cannot design masonary structures in Etabs or safe? What's the main reason behind?
You cann't just assume. This is very dangerous.
You cannot design masonry in ETABS because masonry behaviour is different. Since you are a fresh engineer, I would suggest that you spend sometime understanding difference between masonry and concrete behavior. Read articles from internet and search.
We cannot design masonry in ETABs because the software does not have Masonry design code in its library. It will not perform calculations required for determining shear strength of the x-section modelled in ETABS, and it will not check if the compressive/tensile stresses are within limits.
But, you can analyze it in the software. Get the forces, and perform the required checks manually.
can you suggest design codes/manuals for design of masonry in brick and concrete blocks?
There are various resources. Search for masonry or reinforced masonry and you will find books and design guidelines.
I have used US and Canadian code for masonry. I have also used a book regarding seismic design of masonry from Thomas Paulay and M.J.N Priestley as a reference as well.
ACI 530/530.1-13, “Building Code Requirements and Specification for Masonry Structures and Companion Commentaries"
