ETABS error message
JL07
Hello,
Does anyone know the origine of and how to solve the following error message in ETABS:
" Error in recovering group results:
CSI.SAPmodel.cReadSAPBase.GetReponseGroup: CsiGo error
Details: kFatal=22 "
Many thanks
Just delete/ erase your group assign. Save the model and close file. Import text file of model, the "$et" extension in a new blank model. check if there is any error or warning message. If no, do a relabel all, save and assign groups. Hopefully this will resolve the problem
@JL07, did this tip help solve the issue?
Hello,
What I found is that the issue comes up only when I work with Microsoft OneDrive activated. When I close Microsoft OneDrive and run the model, it works normally. This is probably the reason why etabs technical support wasn't able to reproduce the error.
Thank you all for your replies and help.
On 4/9/2021 at 4:06 AM, JL07 said:
Hello,
Thank you for updating on this. If someone else gets into the same issue in the future, your post would be of great help to them.
    • I am designing a G+2 factory building founded on dense sandy soil as per our geotechnical investigation report.   Load considered:  (As Client was not sure about the purpose of use)  Live Load on Slab= 3.0 kN /m2 Dead Load on Slab= 1.5 kN/m2   (other then Self weight) Grid Spacing: 27'9"x21'3"  Plot Dimensions: 56'x165' Characteristic Load on Columns: (decisive case) Dead Load: 1900 kN Live Load: 950 kN The report recommended bearing capacits: Isolated Footing: 160 kPa at 2.0m depth  Settelment within 25 mm Raft foundation  300 kPa  at 2.0 m below existing ground level (EGL), With the column loads of around 2800 kN and grid spacing isolated footings would require very large foundation sizes leaving little or no clearance between footings and cause overlap issues. Therefore i decided to go for raft foundation.   However, the site condition is such that: The EGL (existing ground level) in the report corresponds to be the site’s current level +0.0 m, while the outer road level is about +0.9 m higher. Our finished factory floor will be at +1.5 m. Now i am evaluating two options: Option A – Construct the raft foundation at the recommended -2.0 m below EGL (per the GI report), then build up columns, cast a plinth beam at the raised level, backfill up to the required ground/floor level, and finally prepare a floor over the compacted backfill. Option B – Raise the site to match the road level using engineered, well-compacted backfill, and then construct the raft foundation directly at the new raised ground level, allowing the raft slab itself to serve as the factory floor. I want to understand: Which option is more technically sound and economical considering bearing capacity, settlement control, and long-term performance? Is placing the raft on engineered backfill (Option B) acceptable practice if compaction and quality control are ensured, or is it safer to strictly follow the geotechnical recommendation (Option A)? Any insights or experience-based advice on this choice would be highly appreciated. Furthermore:  Are the load assumed too conservative? Kind Regards Abdul Malik
