Interview questions
Muhammad Hashmi
Assalam O Alykum
I gave very hard interview questions (at least for me )in famous international engineering consultancy on Microsoft team. Might be it looks very easy for many of you.
Just want to share my experience.  If seniors can have a look on the questions which i remember and my replies to them. I believe should not ask with a guy having less experience. However, I am expecting to receive positive response.
Questions are underlined ,but not in sequence.
Thank you
Interview q.pdf
On 4/11/2021 at 7:42 AM, Muhammad Hashmi said:
Assalam O Alykum
Thank you
Interesting. Thanks for sharing.
Unfortunately in Middle east i have experienced something similar, the person taking interview might not necessarily know all these answers as well but he will come up with these questions just to make sure that you know nothing and he knows everything, a bit unprofessional attitude, the questions should be as per the experience of the guy and the job description. I found out the reason for the interviews to be like that they prefer the reference alot rather going through interview process. Its just what i have seen definitely not same for all organisations.
    • I am designing a G+2 factory building founded on dense sandy soil as per our geotechnical investigation report.   Load considered:  (As Client was not sure about the purpose of use)  Live Load on Slab= 3.0 kN /m2 Dead Load on Slab= 1.5 kN/m2   (other then Self weight) Grid Spacing: 27'9"x21'3"  Plot Dimensions: 56'x165' Characteristic Load on Columns: (decisive case) Dead Load: 1900 kN Live Load: 950 kN The report recommended bearing capacits: Isolated Footing: 160 kPa at 2.0m depth  Settelment within 25 mm Raft foundation  300 kPa  at 2.0 m below existing ground level (EGL), With the column loads of around 2800 kN and grid spacing isolated footings would require very large foundation sizes leaving little or no clearance between footings and cause overlap issues. Therefore i decided to go for raft foundation.   However, the site condition is such that: The EGL (existing ground level) in the report corresponds to be the site’s current level +0.0 m, while the outer road level is about +0.9 m higher. Our finished factory floor will be at +1.5 m. Now i am evaluating two options: Option A – Construct the raft foundation at the recommended -2.0 m below EGL (per the GI report), then build up columns, cast a plinth beam at the raised level, backfill up to the required ground/floor level, and finally prepare a floor over the compacted backfill. Option B – Raise the site to match the road level using engineered, well-compacted backfill, and then construct the raft foundation directly at the new raised ground level, allowing the raft slab itself to serve as the factory floor. I want to understand: Which option is more technically sound and economical considering bearing capacity, settlement control, and long-term performance? Is placing the raft on engineered backfill (Option B) acceptable practice if compaction and quality control are ensured, or is it safer to strictly follow the geotechnical recommendation (Option A)? Any insights or experience-based advice on this choice would be highly appreciated. Furthermore:  Are the load assumed too conservative? Kind Regards Abdul Malik
