Importing ETABS file from v19.1 to v18.1
Assalam O Alykum
In one of our health care project , the structural design is made by Spanish consultant. The structure is designed and analyzed by E-tabs version 19.1.0 ( Licensed )by them.
The problem is that , in our office we are using E-tabs version 18.1.0 ( Licensed as well).
After request they send us E2K file to import the model in Lower version. When I am going to import E2K on the E-tabs version I have it destroys whole geometry.
Second trial I made is to change the version name to 18.1.0 on the $ file which they also forwarded to us.
but the result is same. I am also attaching the snap shot of geometry which I am seeing after import.
Can anybody advise. What can be the possible solution? other than to update our version to 19.1.0.
Thank you
  • UmarMakhzumi changed the title to Importing ETABS file from v19.1 to v18.1
Assalam O Alykum
EDB file of version 19 is now opened in 2018. The below identified by the external consultant
Dear Hashimi;
 I think I have found the problem, maybe It can be the configuration of decimals in your computer. I have the decimals as “,”. Maybe you have the configuration with “.”.
 We have had sometimes problems due to the different configurations in our computers.
  attach the .e2k file exported in a computer with the configuration “.” of the decimals.
 Tell me if you can export it fine.
 Kind regards.
    • I am designing a G+2 factory building founded on dense sandy soil as per our geotechnical investigation report.   Load considered:  (As Client was not sure about the purpose of use)  Live Load on Slab= 3.0 kN /m2 Dead Load on Slab= 1.5 kN/m2   (other then Self weight) Grid Spacing: 27'9"x21'3"  Plot Dimensions: 56'x165' Characteristic Load on Columns: (decisive case) Dead Load: 1900 kN Live Load: 950 kN The report recommended bearing capacits: Isolated Footing: 160 kPa at 2.0m depth  Settelment within 25 mm Raft foundation  300 kPa  at 2.0 m below existing ground level (EGL), With the column loads of around 2800 kN and grid spacing isolated footings would require very large foundation sizes leaving little or no clearance between footings and cause overlap issues. Therefore i decided to go for raft foundation.   However, the site condition is such that: The EGL (existing ground level) in the report corresponds to be the site’s current level +0.0 m, while the outer road level is about +0.9 m higher. Our finished factory floor will be at +1.5 m. Now i am evaluating two options: Option A – Construct the raft foundation at the recommended -2.0 m below EGL (per the GI report), then build up columns, cast a plinth beam at the raised level, backfill up to the required ground/floor level, and finally prepare a floor over the compacted backfill. Option B – Raise the site to match the road level using engineered, well-compacted backfill, and then construct the raft foundation directly at the new raised ground level, allowing the raft slab itself to serve as the factory floor. I want to understand: Which option is more technically sound and economical considering bearing capacity, settlement control, and long-term performance? Is placing the raft on engineered backfill (Option B) acceptable practice if compaction and quality control are ensured, or is it safer to strictly follow the geotechnical recommendation (Option A)? Any insights or experience-based advice on this choice would be highly appreciated. Furthermore:  Are the load assumed too conservative? Kind Regards Abdul Malik
