Base fixity for column and shear wall
Abdallah123281
‏‏I have a quesion about proper model, analyze and design using etabs , i have no clear way to assign partial fixity for column and shear wall base , according to BS 5950 , which shown in the figure , it depents on the rigidity of the connection between member and footing , and found no way to evaluate this rigidty , so , i assume that i can assume pin connection at the base for all structural members and this is more conservative for building design , but how to design footings , should i make fixed base supports to get highest moments and design footings , is this too much conservative design ?
If its a good way to design , and because i have shear walls that i design to handle all lateral load , can i assign fixed support for shear walls only when design footings and pin them when design whole structure ? Or this is not relevant ?
The attached information is related to design of steel structure (portal frames).
This is is not related to your design. For shear wall based structures, it does not matter whether you assign fixed or pin support. Only soil-structure interaction (SSI) will change your results.
The simplest way to model SSI is to use Winkler springs under the foundation. For that, you will have to model footing with shell elements and assign springs based on modulus of subgrade reaction to the bottom and side faces of foundation. If you have below grade stories, you can assign springs to your basement walls as well.
The detail discussion on the subject can be accessed through these documents
  • NIST GCR 12-917-21 Soil-Structure Interaction for Building Structures
  • FEMA P-2091 A Practical Guide to Soil-Structure Interaction
