BLOCK WALL AT FIXTURES
Muhammad Hashmi
Assalam O Alykum
In one of our under construction project we are using hollow block work walls.
My question is at the location of fixtures toilet or kitchen ( Wet areas) means WC and Wash basin,
Solid block work wall is better or Filled the layer with M20 concrete as the hollow block work will surely get crack after some time.
Thank you
Hollow concrete blocks if made following standard procedure are usually very durable and have substantial strength. As far as i know, these blocks have low water absorption than conventional bricks. I think if they are properly placed with high quality mortar, you shouldn't have a problem.
You should take my advice with agrain of salt since this type of construction is not very common in pakistan.
Edited by ANStructs
