Concrete compressive strength evaluation of bored piles
abbaskhan2294
Hello members I hope this thread finds you well.
My query today is related to compressive strength of concrete bored piles. The issue is that pilegroup with 24 no of piles have been casted almost two years ago but there were observations regarding quality control on couple of piles in the group which are not known. Now the higher-ups are recommending to resume the project again and unfortunately I'm the incumbent and have to propose a methodology. Now the question is that since the piles are already buried underground, which procedure shall be adopted to predict its compressive strength near to its actual. Your suggestions will highly be appreciated. Thanks.
Edited by abbaskhan2294
Hi Abbas
The special GPR (Ground penetration Radar test) looks suitable for your case that is generally applied to check the workability of concrete joint ,  honey comb , cold joint or weak concrete , change in properties of material. Voids and cracks by using electromagnetic radiation for that type of structure.
7 hours ago, Muhammad Hashmi said:
Hi Abbas
Thanks bro for your reply. Exactly what I have been thinking to adopt. If there is any pile that is not meeting the standards will definitely have a changed profile and will be helpful in indicating the defective pile. In addition destructive tests on extracted cores will aide to the investigation.
There are different way depending upon the risk category of the structure.
Pile capacity of concrete is one things and geotechnical capacity is another. The best way would be to do a pile load test on this pile group. Geotechnical consultants normally do such test and it helps verify capacity of existing piles both structurally and geotechnically.
For concrete strength, like you said core testing is one way. I am not familiar with GPR for strength testing of concrete piles. I have seen a lot of results of GPR surverys to find buried lines but nothing to determine strength.
Hope this helps.
Hope this helps.
The full scale pile group load test would be quite difficult to execute + due to defective piles there are greater chances of settlement and thus making the entire pile group sink as a result extra loss to the contractor and a complete failure of project. So I would rather opt for concrete core tests. In addition GPR will be useful in giving idea about the condition of pile. So any pile with weak concrete mix will possibly be identified using GPR as per my observations.
    • I am designing a G+2 factory building founded on dense sandy soil as per our geotechnical investigation report.   Load considered:  (As Client was not sure about the purpose of use)  Live Load on Slab= 3.0 kN /m2 Dead Load on Slab= 1.5 kN/m2   (other then Self weight) Grid Spacing: 27'9"x21'3"  Plot Dimensions: 56'x165' Characteristic Load on Columns: (decisive case) Dead Load: 1900 kN Live Load: 950 kN The report recommended bearing capacits: Isolated Footing: 160 kPa at 2.0m depth  Settelment within 25 mm Raft foundation  300 kPa  at 2.0 m below existing ground level (EGL), With the column loads of around 2800 kN and grid spacing isolated footings would require very large foundation sizes leaving little or no clearance between footings and cause overlap issues. Therefore i decided to go for raft foundation.   However, the site condition is such that: The EGL (existing ground level) in the report corresponds to be the site’s current level +0.0 m, while the outer road level is about +0.9 m higher. Our finished factory floor will be at +1.5 m. Now i am evaluating two options: Option A – Construct the raft foundation at the recommended -2.0 m below EGL (per the GI report), then build up columns, cast a plinth beam at the raised level, backfill up to the required ground/floor level, and finally prepare a floor over the compacted backfill. Option B – Raise the site to match the road level using engineered, well-compacted backfill, and then construct the raft foundation directly at the new raised ground level, allowing the raft slab itself to serve as the factory floor. I want to understand: Which option is more technically sound and economical considering bearing capacity, settlement control, and long-term performance? Is placing the raft on engineered backfill (Option B) acceptable practice if compaction and quality control are ensured, or is it safer to strictly follow the geotechnical recommendation (Option A)? Any insights or experience-based advice on this choice would be highly appreciated. Furthermore:  Are the load assumed too conservative? Kind Regards Abdul Malik
