When to use P Delta analysis...
Zeeshan Ahmad
The concept:
Member deforms when it receives nodal forces which can be axial, moment, torsion, and shear acting  either individually or in combination with other types. In its deformed shape, the gravity force tends to deform the structural member further, thus leading to an increase in end moments. These are called second order effects.
These effects are significant for slender members only.
In addition, code requires you to check the drifts in your structure with an analysis that incorporates this P-delta effect so as not to underestimate .
If P-delta analysis does not converge:
  • Check model for connectivity issues
  • Check model for cantilever elements not connected to slab or any other bracing member
  • check meshing
  • P-delta analysis also fails to converge is you have membrane assignment to your area elements
  • if all of above is ok, make it stiffer.
