Long Term Deflection Multiplier
jammer3425
long term deflection multiplier accounts for deflection in members due to shrinkage and creep behavior in an approximate way. It is approximate because instantaneous dead deflection is multiplied by deflection multiplier and then this value is added in DL and LL deflection to get long-term deflection.
Self weight multiplier option is used the software to compute dead weight of structure.If it is 1 then dead dead weight will be multiplied by 1.
I edited title of thread as it can help in searching for particular topic in forum,I hope you will not mind.
I have currently with me some papers, i was reading...and making notes...luckily the topic is LONG TERM DEFLECTION :P
It is still in my pending tray...Once i find enough time to get information and absorb the topic i will write a post and share with you all. Well i was doing research on LONG TERM topic and also how to use it in SAFE and what are different options available in SAFE...well i made a comparison sheet and i found every result different than the rest...which made me more confused....
but not all the things can be done manually in a fast track project...yeah should be done manually to understand the concept but to get faster results one should be familiar with computing techinques too
I prefer adding such effects manually. Once you have your stresses just do manual calculations and superimpose
When you know what you are doing, its doesnt matter its fast track or slow track!
I just presented an explanation to the use of computing techniques if somebody has taken it the other way round then read my post again which support in favour of being faster in the present world by use of computing techniques rather then being slower with the manual calculations and why i said k duniya jeenay nhn daiti because a person with good computing techniques is more prefferable to any organization then a person with clear concepts a person with good GPA is far far better than the one trying to clear concepts for which i said k look behinf and see how many have we left behind and thanx for the reminder i forgot the language of the forum is english for which i appologise to moderators and others concerened
computing is necessary tool but a good engineer must know how to do it manually and if in case there is no computing facility or there is any problem one must be capable of cheking it manually, using the computing tools blindly is not good!!!how fast or how slow you are in computing depends it is not the fastness it is the accuracy and professionalism which lets you fly high in the profession !!! and a professional person can never be replaced he has his best position always otherwise he himself feels uneasy !!!
