I need clarification plz.
sajjad Ahmed
Generally lap zone in columns  is kept at mid height of floor.  I have confusion that mid height of floor is  taken from cieling level or beam bottom level.
For example if height of floor is 16'(including slab pour)   and beam botton is at 14' , for column lap we take mid height of  floor.   In this example which height will be considered for mid height calculation.?
I'm not sure what a lap zone is... is this a splice location?  If so, in these environs, splices generally occur at finished floor level in multi storey concrete buildings.  For steel buildings I put them about 2' (600mm) above finished floor.
Same rules apply for Steel AND concrete when it comes to splicing members. Although in concrete its reinforcement laps.
Splices are expensive and hence you find the location with minimum bending and shear to splice at.
With concrete its not splices as such, but bar lap lengths. The Canadian codes will have their rules for lapping reinforcement - for both compression and tension locations. 40 times the diameter of rebar is a good rule of thumb, if there are no codes available.
Point of minimum moment is likely about mid height of the column; it's not generally convenient to splice at that level.
