Torsion in Buildings
Kasim
i have attached the photo of Modal mass participation Ratio of the Model, is The first mode is Torsional? As the RZ is 0.19 of the mass, and Can we allow Torsion in first mode?
and is the First or the 2nd mode is the Fundamental one?
1. Yes we can allow torsion or anything in a building as long as you are designing for that (uneconomical).
2. Fundamental mode? What is a fundamental mode? A mode with highest mass participation.
3. Why you are just looking at Rz in first mode?
From the table you attached, in my opinion;
First mode = Mode2 of ETABS with 54.56% mass participation in X direction. (T=0.553s)
Second mode = Mode3 of ETABS with 36.33% mp, rotation in Z direction (T=0.505s)
Third mode = Mode1 of ETABS with 34.75% mp in Y direction (T=0.586s)
Remember that ETABS lists mode based on descending order of T and not mass participation but in my opinion we should sort modes based on mp. Moreover, You have to check that modes are not "CLOSELY SPACED". That means, if you look at T above, you will find that translational modes (T=0.553 & 0.505s) are very close to torsional mode (T=0.586s). This is bad. Try changing configuration of your building. You can still continue designing like that but ofcourse its more economical (bad design).
From the data you provided, it looks like your building is undergoing translational+rotational in a complex way all at once. The shape, geometry, configuration of shear walls etc is not regular or you are trying to model a very stiff and very flexible elements together like a concrete basement supporting a light steel roof/canopy.
Thank you Waseem Sir, This is A four Storey Building having Basement Shear walls and Having Two Elevators Which  are not Symetric about X Axis, Will make it symetric and then will hear from you, :)
  • 6 months later...
This topic is very informative. Thanks for the replies. But I think I am lagging interpreting the table. I have the following table and cant interpret. Can anybody help what does the table say and how does it effect the design?
Case Mode Period
sec
UX UY UZ Sum UX Sum UY Sum UZ RX RY RZ Sum RX Sum RY Sum RZ
Modal 1 0.719 0.3 0.1009 0 0.3 0.1009 0 0.0699 0.2062 0.2 0.0699 0.2062 0.2
Modal 2 0.702 0.0932 0.5007 0 0.3932 0.6015 0 0.3481 0.064 0.0103 0.418 0.2702 0.2102
Modal 3 0.642 0.2212 0.0081 0 0.6144 0.6096 0 0.0056 0.1487 0.3996 0.4237 0.4189 0.6099
Modal 4 0.217 0.0267 0.0377 0 0.6411 0.6473 0 0.0578 0.0441 0.0252 0.4814 0.463 0.6351
Modal 5 0.212 0.036 0.0492 0 0.6771 0.6965 0 0.0752 0.0581 0.0039 0.5566 0.5211 0.639
Modal 6 0.196 0.029 0.0037 0 0.7061 0.7002 0 0.0057 0.0445 0.0628 0.5623 0.5655 0.7018
Modal 7 0.119 0.0042 0.0131 0 0.7103 0.7133 0 0.007 0.0025 0.0103 0.5693 0.5681 0.7121
Modal 8 0.114 0.0163 0.0097 0 0.7267 0.723 0 0.0055 0.0096 0.0007 0.5747 0.5777 0.7128
Modal 9 0.108 0.0074 0.0037 0 0.734 0.7267 0 0.0022 0.0043 0.0177 0.577 0.5819 0.7305
Modal 10 0.092 1.318E-05 0.0046 0 0.734 0.7313 0 0.0072 2.301E-05 0.0021 0.5842 0.582 0.7326
Modal 11 0.038 0.2543 0.0002 0 0.9883 0.7315 0 0.0004 0.3844 0.0005 0.5846 0.9663 0.7331
Modal 12 0.037 0.0021 0.0009 0 0.9904 0.7324 0 0.0025 0.0032 1.603E-06 0.5871 0.9695 0.7331
1. Increase modes from 12 to have SumRx more than 90%.
2.
first mode is translation in x plus some torsion.
second mode is pure translation y.
third mode is torsional + x-translation.
it appears that you have irregularities in x direction (CM and CR are at different locations).
  • 4 years later...
Hello, I am doing modal analysis of an irregular building (mass irregularity and torsion). I am facing difficulties interpreting the table and what modes should be considered to reached 90% MPMR. I have the following table and i can't interpret. Can anybody helps me to obtain the appropriate mode shapes?
Thnak you,
Ayman,
You will need to see the mass participation per mode and then make sure you have enough modes (sum up the mass participation for each mode) to meet your building code requirement (90% or something varies from Code to Code).  If you didn't have enough modes when you sum up the modal mass participation per mode, then you need to increase the number of modes thill you sum hits the magical number as specified in the code. The table above is showing displacements per mode is different than what you should be looking at.
  • 3 years later...
I'm having a hard time understanding this table. My supervisor said the sum of Ux Uy Uz Rx Ry Rz for the first three mode should be 100% but now it is not. Also for the first three mode there should be at least one cell from Rx Ry Rz to be a relatively large number respectively. Could anyone help me with that please!image.thumb.png.21e0950534c48ada4794d21798ae65fa.png
  Quote
do we need to check it for only sum Ux and Sum Uy or others as well ??? Also, how important is to check Rx and Ry while considering an individual mode as translational or rotational ???
Can elaborate this more ..having closer time period for translation and torsional how effects the buidling performance ???
means that the fundamental mode is not the one with highest time period ???
I am working on a high rise building (overall 69 stories, 10 stories of carpark, transfer slab at level 12) located in a very low seismic zone (PGA 5%g). The building first mode is translational (i considered Ux, Uy and Uz tables for this classification) and 2nd mode is torsional followed by 3rd mode again in translational.
The modal mass participation ration as shown below. I considered the default 12 modes and getting the required overall 90 percent mass participation both in X and Y direction (Sum Ux and also Sum Uy) but didnt consider the SumUz or ther SUm Rx,Ry and Rz. Is this important ???
I understand that ideally the first 2 modes should be translational followed by torsional mode and this can be achieved with proper structural distribution of elements on the floor plans however for this building the design was freeze and the design team want to proceed. After the response spectrum analysis, i showed them that the higher reinforcement in column and shear walls are resulting from this torsional behavior in 2nd mode. My question is that we have incorporated additional reinforcement tin these shear walls and columns however the slab diaphragm needs any attention ??? or any other element like designing diaphragm particularly at the transfer level to ensure that it receives this torsion and transfer safely to shear walls and columns ??
Edited by Zain Saeed
