Importing of etabs 9.7.4 file to 2016
vasavi
Normally, a lower version file may be opened directly in a later version of same software. So, start ETABS 2016 & try to open your older version .edb file directly.
In case it does not work, you my use text input file (having .et extension) of your ETABS  9.7.4 model, for importing it into ETABS 2016.
If you still face some problem, describe it here, for further advice.
  • 3 years later...
