MAXIMUM REINFORCEMENT FOR BEAM IN ETABS
Saiful Islam Zaber
Maximum reinforcement in beams (flexure only members) are controlled by maximum net tensile strain. The above-mentioned limit corresponds to 8% max reo (4% on each side), similar to column.
Beams usually have reo less than 2%. If you are trying to put more reo in a beam using ETABS, change that section property from beam to column. I always love the idea of putting beams as columns in ETABS.
A frame section in ETABS defined as a 'column' will be designed for flexure in both direction + axial loads,  a true interaction diagram. If defined as beam, ETABS wil ignore any axial load (if present) in beam design.
@Rana very well explained ... Thank You
