Column development length in Raft Inward or Outward
Hamza Irshad
Muhammad Picture 1 you mean?
Practically V.difficult to bend bars of vertical members particularly when reinforcement is cutting at site. Second too much congestion of rebars when higher value of additional bottom req in case of Raft.
On 6/10/2021 at 4:34 PM, Badar (BAZ) said:
From the seismic point of view, the former is recommended by the code (ACI 318-19). See the attached:
Assalam O Alykum
Mohammad, something mentioned in addition to the above clause you had extracted from ACI 318-19 in ACI 318-11.
I think its related to SDC D, E & F. If you don't mind can you comment.
Yes, it has been prescribed for structures falling under seismic design category (SDC) D, E or F; these buildings are detailed to achieve higher ductility. The detail achieves higher ductility, so no need to do bend the column-longitudinal bars towards the centerline if ductility demands are low (structure need to satisfy the ACI 318 guidelines pertaining to SDC A,B and C for those).
  1. Hooks are provided for to resist seismic movement.
  2. To prevent concrete from splitting outward.
  3. It prevent slippage of steel from the concrete.
    In Detailing book M. Y. H. Bangash .
