Shear profile for an infilled RC frame
Samra Masood
I have done a pushover analysis of 3-storey 1-bay masonary infilled frame using opensees  and as i look into the shear profile of the frame at various time steps the shear in cols is a little negative intially and then becomes positive and the increases in the positive direction with the increasing lateral load until the infill breaks.... why is it negative initially (i.e. in the elastic range)?
Can you please share how the load has been applied to the 1-bay, 3 story masonry infilled frame?
Also, what is "openness" ? It would be beneficial to see the deflected shape at different time steps. In general principle the response of a frame modelled with masonry struts should be similar to that of a braced bay. I can't think of a reason why the col shear is negative in elastic region other than application of load that causes negative shear and then with time the load changes and so does shear. It might be beneficial to look at how load is being applied with time and we can discuss it.
Thanx for your kind response, for those who are following the post, i have figured out the problem and thought to share so that others may benefit from it. Actually the results that appear slight negative initially are due to the gravity analysis done before, as the load later increases with each time step the lateral force on frame increases leading to positive shears in cols.
  • 5 months later...
Plz send the procedure of design INFILL FRAME in ETABS
    • I am designing a G+2 factory building founded on dense sandy soil as per our geotechnical investigation report.   Load considered:  (As Client was not sure about the purpose of use)  Live Load on Slab= 3.0 kN /m2 Dead Load on Slab= 1.5 kN/m2   (other then Self weight) Grid Spacing: 27'9"x21'3"  Plot Dimensions: 56'x165' Characteristic Load on Columns: (decisive case) Dead Load: 1900 kN Live Load: 950 kN The report recommended bearing capacits: Isolated Footing: 160 kPa at 2.0m depth  Settelment within 25 mm Raft foundation  300 kPa  at 2.0 m below existing ground level (EGL), With the column loads of around 2800 kN and grid spacing isolated footings would require very large foundation sizes leaving little or no clearance between footings and cause overlap issues. Therefore i decided to go for raft foundation.   However, the site condition is such that: The EGL (existing ground level) in the report corresponds to be the site’s current level +0.0 m, while the outer road level is about +0.9 m higher. Our finished factory floor will be at +1.5 m. Now i am evaluating two options: Option A – Construct the raft foundation at the recommended -2.0 m below EGL (per the GI report), then build up columns, cast a plinth beam at the raised level, backfill up to the required ground/floor level, and finally prepare a floor over the compacted backfill. Option B – Raise the site to match the road level using engineered, well-compacted backfill, and then construct the raft foundation directly at the new raised ground level, allowing the raft slab itself to serve as the factory floor. I want to understand: Which option is more technically sound and economical considering bearing capacity, settlement control, and long-term performance? Is placing the raft on engineered backfill (Option B) acceptable practice if compaction and quality control are ensured, or is it safer to strictly follow the geotechnical recommendation (Option A)? Any insights or experience-based advice on this choice would be highly appreciated. Furthermore:  Are the load assumed too conservative? Kind Regards Abdul Malik
